Power over Ethernet switches
By Leslie Langnau | October 30, 2017
Stride PoE+ switches allow Ethernet network cables to also carry electrical power. Normally two connections are required, a network connection and a power connection. PoE reduces the time and expense of having electrical power cabling installed.
Two versions of Stride PoE+ switches are available: 10/100 Mbps and GbE. Both have one standard RJ45 Ethernet port and four PoE+ RJ45 ports (30 W on each port). Using Powered Device (PD) Detection, the PoE switch port will detect the presence of a PoE enabled device before sending power. If a non-PoE device is detected, power will not be sourced on that port but Ethernet communications will be permitted.
Power input requirements are 54-58 Vdc for PoE+ (30 watts per port) and 48-58 Vdc for PoE (15.4 watts per port). The switches provide broadcast/network storm protection and have redundant power inputs.
With IP30 metal cases, these PoE switches have a wide -40 to +75°C (-40 to +167°F) operating temperature range and are approved for HazLoc environments. The switches are DIN rail mounted and an optional panel mounting bracket is available.
AutomationDirect
www.automationdirect.com/poe-switches
Filed Under: Design World articles, Flanges • supports • mounts • brackets, Networks • connectivity • fieldbuses
Tagged With: automationdirect
More on engineering and science
Dan Arvizu: Embracing the soft skills
