  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
      • EE World Digital Issues
    • 2020 LEAP Awards
    • Motion Design Guide Library
    • Suppliers
  • COVID-19
Power of V8 … and nanometer precision positioning in PI’s new piezo linear motor
By Lisa Eitel | June 5, 2017
Motion control and piezo systems expert PI (Physik Instrumente) introduces a new robust OEM walking motor drive, the N-331, with its configuration rooted in existing patented piezo actuator technology and a patented piezo stepping motion principle design. Based on the application of historically successful technology, the new design it is suitable for use in high-end applications that require extreme precision and durability.
Unlike traditional electromagnetic motors, piezo motors do not create magnetic fields, nor are they influenced by magnetic or electric fields — a characteristics that is advantageous in applications from e-beam lithography to MRI technology.
When large optics, detectors or camera set-ups in industrial applications must be positioned with nanometer precision, it can be beneficial to cut the actuator power once the fine positioning process is complete. If a motor or actuator is dependent on a continuous current draw to hold a position, heat dissipation, electromagnetic fields and thermal effects may have negative influences on the performance of the system. PICMAWalk motors are self-clamping, i.e. at rest or in steady state mode, they automatically hold the position without any need for power.
PI’s PICMAWalk piezo linear motor uses 8 PICMA piezo actuators arranged in a V-shape similar to a classical V8 engine to achieve high push/pull and holding forces along with nanometer precision. The space-tested PICMA actuators are highly reliable, providing 60N (13lbs) power-off holding force and 50N (11 lbs) push/pull force. The maximum velocity is specified at 15mm/sec (0.6 inch/sec) and loads up to 5kg (11lbs) can be positioned with nanometer precision.
Open and closed-loop designs: The units are available with 3 standard travel ranges from 25 to 100mm in both open and closed-loop configurations. The closed-loop models incorporate a high-precision incremental encoder with nanometer resolution. The calculated piezo-mechanical resolution is better than 1/10 nanometer.
For maximum precision and reliability, the piezo actuators are integrated in a solid-state flexure guiding system, free of stiction and friction. Flexure elements combine high stiffness and load capacity. They do not require maintenance or lubricants, are 100% vacuum compatible, function in a wide temperature range, and are intrinsically wear-free.
Standard and custom: In addition to the standard models, custom designs for OEMs are available, facilitated by the modular design.
Applications: Optics, microscopy, automation technology, imaging technology, medical engineering. For more information, visit pi-usa.us.
About Lisa Eitel
Lisa Eitel has worked in the motion industry since 2001. Her areas of focus include motors, drives, motion control, power transmission, linear motion, and sensing and feedback technologies. She has a B.S. in Mechanical Engineering and is an inductee of Tau Beta Pi engineering honor society; a member of the Society of Women Engineers; and a judge for the FIRST Robotics Buckeye Regionals. Besides her motioncontroltips.com contributions, she also leads the production of the quarterly motion issues of Design World.
Tell Us What You Think! Cancel reply
MOTION DESIGN GUIDES
  • Drilling Rig OEM Benefits from a PLC with Edge Computing Technology: IIoT Case Study
  • #1 Reason for Retaining Ring Failure & How to Overcome It
  • Motion controllers: design from scratch or buy ready-made?
  • 4 Key Trends in Machine Engineering
  • Configuration Management: Configuration Integrity IS A Core Driver for Business Success
  • How to Choose a Linear Actuator
Tweets by @DesignWorld
  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
    • 2020 LEAP Awards
    • Suppliers
  • COVID-19
