Power Supply
By Design World Staff | March 1, 2007
The 480W SPD Series Switching Power Suppy has 24 Vdc (20 amp) and 48 Vdc (10 amp) outputs, short circuit, overvoltage and overload protection, “Power OK” and “Low Output Voltage” LEDs, and a relay output for “Power Ready.”  Power Factor Correction and Parallel Connection are also standard.It has universal 90-265 Vac or 120-370 Vdc supply voltages, and diagnostic displays that signal the output voltage is ready to use or that it is too low.  All models have internal noise filtering and a potentiometer for tuning the dc output voltage.
The unit comes with a rugged metal housing, screw terminals or detachable connector with screw terminal connections, and an extended temperature range of  -25 to +71° C.  For parallel operation, a built-in decoupling diode is included.  SPD power supplies are UL, cUL, TUV, and CE approved.
Carlo Gavazzi
www.gavazzionline.com
Filed Under: Factory automation, Power supplies
