PowerGrip® Rubber Synchronous Belts
By Design World Staff | March 16, 2009
PowerGrip belts have solved real-world application requirements for more than 60 years. In working with Gates to conceive an innovative belt drive solution, you’ll find a partner that exceeds your expectations.
PowerGrip belts are used in a diverse range of applications requiring speed, strength and durability — from timing belts for automobiles to heavy-duty belts and sprockets for factory-grade machinery — and in the OEM, and replacement markets.
Just one of the belts in the industrial line is the PowerGrip GT®2 belt, which offers:
•High horsepower and torque-carrying capacity
•Low noise and vibration with narrower drive designs
•Accurate registration
•No maintenance or equipment downtime
•Excellent abrasion resistance
•Long life
In fact, it features twice the HP capacity as HTD®, GT and competitive RPP® belts, allowing smaller, more compact drive designs for the lumber/pulp processing, food processing, packaging, aluminum/steel production markets and numerous others.
PowerGrip Twin Power® belts provide double-sided power and synchronization, while TruMotion® belts are clean running, small pitch belts for contaminant-conscious applications.
In addition to the range of high quality products, Gates offers the engineering and design resources to support you from project conception to completion.
www.gates.com
Filed Under: Belts + chains
