PPG adds two new adhesives to its aerospace product portfolio
By Michelle Froese | March 1, 2024
PPG has added two adhesives to its aerospace product portfolio that provide performance and sustainability benefits for OEM and MRO customers.
PPG has added two adhesives to its aerospace portfolio. PPG PR-2940 is an epoxy syntactic paste adhesive (ESPA) for bonding the internal structures of an aircraft. PPG PR-2936 is an adhesive that incorporates the properties of a shim and sealant for attaching the outer skin of an aircraft to the internal structures.
“We are excited to add these adhesive technologies to our product offering,” said Sean Purdy, PPG global director, coatings and sealants, Aerospace. “They will provide our aerospace customers with significant performance benefits as well as sustainability advantages through lightweighting.”
  • PPG PR-2940 ESPA adhesive is a lightweight potting compound used by original equipment manufacturers (OEMs) and maintenance, repair and overhaul (MROs) customers on secondary aircraft structures. It fills and reinforces the honeycomb structures used to manufacture an aircraft’s internal components, including the inner wing structure, galley, lavatories, overhead bins, and flooring.
  • PPG PR-2936 adhesive is used by OEMs to attach the metallic or composite skin of an aircraft to the internal structures of the fuselage, tail assembly, wings, and stabilizers. This epoxy-based adhesive cures at ambient temperatures and is designed to fill gaps or irregularities between the surfaces of the primary and secondary structures. It combines outstanding mechanical strength with flexibility and micro-cracking resistance across a wide operating temperature window.
“Sustainability is a key priority across PPG, including new product innovations,” said Daniel Sydes, PPG global product manager, adhesives, Aerospace. “These new adhesives offer improved chemistries and low-density properties while maintaining a high strength-to-weight ratio that aids in increasing the fuel efficiency of aircraft.”
Filed Under: Adhesives • epoxies
Tagged With: ppg
