PPG has announced the initial launch of the PPG BOUNDLESS CA6500 series of innovative topcoats for the general aviation market in the U.S. and Canada.
PPG’s new topcoat series offers a comprehensive coating solution with minimum downtime for the aviation sector.
Specifically tailored for light aircraft and helicopters, the series is comprised of low-volatile organic compound (VOC) polyurethane coatings, which are designed to provide excellent durability, performance, and appearance characteristics.
This is with minimal regulated VOC and volatile hazardous air-pollutant (VoHAPS) emissions.
“Customers who fly light aircraft want a quick, comprehensive solution that requires minimal downtime when it comes to repaint, stripping or touch-up services,” said Vignesh Palanivel, PPG global product manager, aerospace coatings. “They also desire cost-effective coatings and varied color palettes that suit their identity and imagination.”
Historically, light aircraft manufacturers have used non-aerospace topcoats to protect their aircraft, but they had to contend with drawbacks like fluid resistance, low gloss, color retention, and little flexibility. The PPG Boundless CA6500 series offers a total environmental coating solution for the light general aviator.
From color matching and blending in customized sizes to seamless delivery, application and appearance, the polyurethane topcoats provide an innovative solution with aerospace-grade performance.
Although targeted to light aircraft, PPG Boundless CA6500 topcoats are compatible with commercial, general aviation and military aerospace epoxy primers and sanding surfacers.
For the series’ initial launch phase, PPG’s Aerospace business is coordinating with long-time distribution partner Painter’s Supply & Equipment dba Cooper Color, a PPG Platinum single-line distributor. Cooper Color will help provide rapid color-matching services and custom-blending solutions directly to customers.
Key benefits include:
- Quick, comprehensive coatings solution with minimum downtime
- Excellent durability, “buffability,” and sandability
- Easy to apply, excellent flow, and leveling properties
- VOC content <350 grams/liter
- Hap’s-free and heavy metal-free formulations
- Resistant to hydralic fluids, lubricating oils, diesel fuel, and water
- Excellent gloss and color retention
- Quick dry with additional thinners
- Wide array of color palettes
You may also like:
Filed Under: Adhesives • epoxies
