Pre-assembled overmolded cables for M12 connectors
By Mary Gannon | July 15, 2022
binder USA introduces pre-assembled and pre-tested overmolded cables for use with M12 connectors. The new ready-to-connect cables eliminate the need for single-core wiring, reducing errors and speeding up installations. They are essential to plug & play and plug & work solutions in M12 field installations. The cables are suitable for usage in industrial networks including CAN, Profibus, and Profinet.
BIN840_binder-USA_ready-to-connect-cables-for-M12_300-dpi
Sensors and actuators have become essential to applications from factory automation to smart farming, greatly increasing the demand for industrial-grade connectivity between signal, data, power cables, and field devices. binder has developed a portfolio of ready-to-connect cables, versatile enough to meet a wide range of application needs. The company also offers ready-to-connect products for the standardized M8 form factor.
Product highlights:
  • Ready to connect
  • No single-core wiring
  • Wide range of connector codings¬
  • Pin count: 3 to 12
  • Straight or angled
  • Molded on one or both sides
binder USA LP
www.binder-usa.com
Filed Under: Factory automation, Wire & Cable Tips
Tagged With: binder
