Precision Edge Welded Bellows
By Miles Budimir | January 8, 2010
BellowsTech, LLC specializes in the design and manufacture of custom designed, precision edge welded bellows and bellows assemblies in an array of dimensional configurations and alloys including Titanium, 316LSS, AM350 SS, Aluminum, and Inconel/Hastelloy.
Serving the semiconductor, high vacuum, oil services, process control and medical device industries, BellowsTech edge welded bellows are available in a full range of diameters ranging from .394 to 26 inches (10 mm to 660 mm), in material thickness ranging from .002 to .036 inch (.05 mm to .91 mm), and in lengths up to 96 inches (24.38 mm).
BellowsTech edge welded bellows provide the most flex in the smallest amount of space and can be used in vacuum applications as valve stem seals, expansion joints, actuators, and vibration dampers and torque couplings.
BellowsTech, LLC
www.bellowstech.com
Filed Under: Bellows, Semiconductor, Motion control • motor controls
49503-ACS Motion-CMxa
SDP-SI-040
PACMotion-servos
