  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
      • EE World Digital Issues
    • 2020 LEAP Awards
    • Motion Design Guide Library
    • Suppliers
  • COVID-19
Precision molding and the Internet of Things
By Leslie Langnau | July 9, 2020
The Internet of Things (IoT) has far reaching ramifications for industry in general and for precision molding in particular. While most analysis of the IoT is in respect of its positive influence on manufacturing processes, the growth in the IoT also opens up huge possibilities for micro-molding as there is increasing demand for new and innovative micro devices.
By Aaron Johnson, VP of Marketing and Customer Strategy, Accumold
There is no doubt that when manufacturing highly complex micro-molded components, data can help to ensure a maximum level of repeatability in the micro-injection molding process, create consistent quality, and mitigate defects. Data also provides the general benefits of reduced downtime through preventative maintenance and machine upkeep.
Terminology is interchangeable in this field. When discussing smart manufacturing many use terms such as IoT, Industrial IoT (IIoT), or Industry 4.0. The actual term IoT was first used by Peter T. Lewis in 1985 to describe as he stated it “the integration of people, processes, and technology with connectable devices and sensors to enable remote monitoring, status, manipulation, and evaluation of trends of such devices.”
So, while the term has been around for a few decades, the concept continues to develop and evolve as technology continues to advance through new hardware, and through the collection and analysis of data.
For precision micro molders in particular, the IoT allows for gains in production efficiencies, improved production quality, and reduced time to market. Machines can communicate failure points and collect data that can be used to improve predictive and preventative maintenance, which in the long run improves uptime. Data analysis is used to predict and prevent failure; it indicates when intervention is required and recommends the necessary corrective actions. Troubleshooting is more efficient, which benefits both manufacturers and customers.
The drive to glean more – and better – data from industrial equipment and systems will continue to improve productivity in the micro-molding sector as technology, sensors, and systems continue to evolve, to the benefit of the molders and their customers.
But there is something else that micro molders understand when looking at the IoT.
The innovative hardware and components that enable smart devices or wearables represent a huge, dynamic and growing market as often these devices are small, intricate, and their manufacture is driven by weight, cost, and time-to-market considerations. OEMs making components that drive IoT devices must engage with highly qualified and experienced micro molders to ensure the efficient and cost-effective manufacture of safety critical precision and micro components. Engaging with a qualified micro manufacturing partner early in the design cycle for new product development is vital to avoid multiple (and costly as well as time-consuming) design and tooling iterations.
Devices that drive the IoT
To see whether something fits under the IoT umbrella, you need to look at interconnectivity. Does one product work with another product? If you lock a window, does a door lock automatically as well? Are light controls connected with the thermostat? As you walk up your garden path, do lights turn on and curtains close as you hit the remote control to unlock the front door?
These examples probably get us closest to a workable definition of the IoT. An IoT is a coordination between multiple devices, and it involves fitting devices with an on/off switch that is connected to the internet. We have seen over the last few years that the number of connected devices has ballooned into the billions, and this exponential growth in the IoT will be driven by the software and hardware that make it all possible.
Governments are deploying IoT applications to alert them to failed street lights, leaks in water systems, and full trash cans etc…. The IoT will also very likely have a major role in traffic control, and forest fire and landslide detection and the like. Remote sensing is already mainstream in many industries, office buildings, and in the energy supply.
However, it’s the consumer applications that get the most attention, because they involve almost every industry and platform: health systems, home energy use, hardware, home building, electronics, and the entire category of wearables, including clothing.
Software-wise, interconnectivity is driven by the use of Bluetooth, devices wirelessly communicating with each other and thus making them intrinsically linkable. Hardware-wise, the key is sensors, or to be accurate “micro-sensors” without which there would be no IoT.
Micro sensors detect and measure temperature, vibration, and the effectively “see and hear” for devices. As we analyze the sensors used on many devices that make the IoT, we are looking into the area of MEMS (micro electro-mechanical systems), tiny components — sometime less than a thousandth of an inch in size — which are critical for IoT functionality.
Often, MEMS are manufactured in much the same way microprocessors are manufactured, through a lithography process. These sensors can be paired with an application-specific integrated circuit or “ASIC.”
The application of MEMS sensors to the IoT-enabled markets will require sensors to shrink further and be more power-efficient.
Today, MEMS are intelligent technical systems or subsystems with advanced functionality, which bring together sensing, actuation and data processing, and informatics/communications. Therefore, these systems not only sense, they also diagnose, describe, and manage any given situation. They are highly reliable and their operation is enhanced by their ability to mutually address, identify, and work in consort with each other. Such smart systems are the hardware basis for the IoT.
From a technology point of view, these smart systems are not limited to silicon–based technologies but integrate polymer-based technologies, printing technologies (for printed antennas, printed sensors, displays or batteries), different nanotechnologies (spintronic devices, CNT-based devices or devices based on embedded nanoparticles), and even embroidering technologies for sensors.
Accumold
www.accu-mold.com
MOTION DESIGN GUIDES
  • With virtual commissioning, commissioning time and prototype waste is reduced
  • Master Bond Supreme 10HT High Strength, NASA Low Outgassing Approved Epoxy
  • Drilling Rig OEM Benefits from a PLC with Edge Computing Technology: IIoT Case Study
  • #1 Reason for Retaining Ring Failure & How to Overcome It
  • Motion controllers: design from scratch or buy ready-made?
Tweets by @DesignWorld
  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
    • 2020 LEAP Awards
    • Suppliers
  • COVID-19
