Precision Plus Linear ball bearings from LEE LINEAR provide excellent life and accuracy, while maintaining high load capabilities. Precision Plus Linear Ball Bearings are self-aligning with integral seals. They are available as just a bearing, or mounted in aluminum housings, in open or closed configurations.
Product Ranges
Maximum Load Capacity: 105–1930 lbf for Closed Bearings, 265–1930 lbf for Open Bearings
Shaft Diameter: 3/8–1-1/2 inches for Closed Bearings, 1/2–1-1/2 inches for Open Bearings
Precision Plus Linear Ball Bearing Pillow Blocks
Precision Plus Linear Ball Bearing Pillow Blocks from LEE LINEAR have all the advantages of Precision Plus Linear Ball Bearings, with the added bonus of mountability. They are available in opened and closed style to fit a wide variety of applications.
Product Ranges
Load Rating: 255–2000 lbf for Closed Bearings, 230–1560 lbf for Open Bearings
Shaft Diameter: 1/2–1-1/2 inches for Closed and Open Bearings
Precision Linear Ball Bearings
Precision Linear Ball Bearings are superior to standard linear ball bearings due to their accuracy, travel life, and high load handling. With a lower coefficient of friction, LEE LINEAR’s Precision Linear Ball Bearings can be used in a wide variety of applications and are offered in Open and Closed styles, with and without seals.
Although LEE LINEAR’s Precision Linear Ball Bearings have a simple mechanism, they have increased travel life and load capacity over other linear ball bearings.
Product Ranges
Bearing Mass: 0.020–2.75 lbs for Closed Bearings, 0.080–2.75 lbs for Open Bearings
Dynamic Load Capacity: 19–1100 lbs for Closed Bearings, 85–1100 lbs for Open Bearings
LEE Linear
www.leelinear.com
The post Precision plus linear ball bearings appeared first on Bearing Tips.
Filed Under: Bearings, Bearing Tips
