Precision pneumatic-to-current P/I transducers
By Paul Heney | August 1, 2012
CA P200Amherst, N.H.—ControlAir Inc. has announced its P200 and P290 pneumatic-to-current P/I transducers. These transmitters are designed to convert standard 3-15, 3-27 or 6-30 psig air pressures into a two wire 4-20 or 10-50 mA signal with a total accuracy up to +/- 0.10%. Customized inputs as low as 0-20-in. w.c. or as high as 0-50 psig are readily available.
The explosion-proof P200 provides accuracy and repeatability as well as a NEMA 4X housing designed for the hazardous environments of the chemical and petrochemical industries, mining or oil and gas fields. It is FM approved and CSA certified as explosion proof for Class I, Div. 1, Groups A, B, C, D; dust ignition-proof for Class II, Div. 1, Groups E, FG; and suitable for Class III, Div. 1 locations. The P200 offers infinite resolution and a response time of 10 m Sec for 99% of step change.
The industrial grade P290 incorporates the same accuracy and reliability as the P200 without the explosion-proof housing. A modular design allows convenient panel or DIN rail mounting for individual or high density applications. The P290 is used extensively in the modern automated process systems of the pharmaceutical, semiconductor, paper and food industries.
The P200/P290 pneumatic-to-current P/I transducers require only a 10 VDC minimum power supply and provide protection from both conducted and radiated RFI from 20 MHz to 1 GHz. Since their solid-state design uses no moving parts and consumes no air, a billion cycle lifetime in shock and vibration environments can be expected.
ControlAir Inc.
Pneumatic Tips
Filed Under: Pneumatic Tips
Paul Heney
