Littelfuse, Inc. has introduced the 59040 Series press-fit reed sensor, the first Firecracker reed sensor from Littelfuse with crush ribs on the capsule that requires no attachment accessories for installation. This magnetically operated sensor is designed to press-fit securely into a 3/8” (9.5mm) diameter hole and offers another sensor option for the competitive reed sensor market. Its enhanced sensitivity allows for a wider air-gap between the sensor and its matching 57040 actuator.
The 59040 Series sensor will be displayed among other Littelfuse products at China’s leading exhibition of electronic components, Electronica China, March 15-17, 2016, in Shanghai, in Booth No. 3522 (E3 Hall).
The sensor is designed for mounting on a fixed surface/frame with the magnet actuator mounted on the moving surface/door. It offers three contact options: normally open, normally closed, and change-over contacts. The 59040 Series press-fit reed sensor is a UL Recognized Component and offers switching capability up to 200VDC/140VAC at 10 W/VA. A range of sensitivity and cable length options are available.
Typical applications for the 59040 Series Firecracker reed sensor include position sensing in appliances, door/window position sensing in security systems; limit sensing in hydraulic cylinders; and speed and distance measuring/sensing for treadmills and bicycles.
Littlefuse
littelfuse.com
Filed Under: Sensor Tips
