Sigma-Netics, Inc., a global manufacturer of pressure switches, pressure transducers, and metal bellows assemblies, has introduced the SST 74X-UV Series depth transducer — a depth measurement device for use with submersible vehicles.
Designed to address the unique sensing requirements of unmanned underwater vehicles, these compact, shallow-diaphragm sensors feature a configurable flange design that allows outboard or inboard bulkhead installation along with digital and analog outputs.
The saltwater- and freshwater-compatible SST 74X-UV transducer delivers ±0.15% full scale output (FSO) total error band (TEB) accuracy, and its heavy-duty construction ensures vibration and shock resistance. Additional features and specifications include:
- Outer diameter: 0.75-in. (19 millimeters) max.
- Lightweight: <0.2 lb. (90 grams).
- Standard ranges: 0-100, 250, 500, -750, 1500, 2000, 3000, 5000, 7000, 10000 psia/psig/psis.
- Wetted parts made from 15-5 PH stainless steel or Inconel.
The SST 74X-UV is the latest in a growing line of Sigma-Netics pressure transducers that stand up to challenging operating environments. In addition to our standard catalog products, Sigma-Netics offers customized solutions for cases in which standard catalog products will not meet an OEM’s application requirements.
Sigma-Netics
www.sigmanetics.com
Filed Under: Sensor Tips
