    • Subscribe!
Prevent dump pump failure with Muncie’s Three-Line System
By Mary Gannon | September 7, 2016
two-vs-three-line-system-dump-pump-failureMuncie Power Products Inc.’s line of dump pumps is available in a three-line system option to help prevent the most common dump pump failure of high temperatures resulting from the pump being operated too long in neutral.
A three-line system includes a separate line to return hydraulic oil from the cylinder directly to the reservoir instead of forcing its way back through the inlet line. The three-line allows faster down cycles and ultimately runs cooler.
Available dump pumps include the E Series and S Series. Both the E Series and S Series are available in the three-line option. Two-line systems are also available. These systems can function effectively, but only if not left operating too long in neutral.
The E Series has a maximum pressure of 2,500 psi and is the standard equipment for tandem, tri-axle dumps and dump trailers with high volume cylinders. Its pressure-balanced wear plates promote high efficiency. Larger port options for fast cycle times are available with the EH model.
Designed for small single or tandem axle dump trucks, the S Series is available in 6, 11 and 15 GPM at 1,000 rpm sizes. The three-way dump pump valve allows for proper single-acting hoist operation on smaller dump truck applications.
www.munciepower.com/dumppumps
Mobile Hydraulic Tips
Tagged With: munciepower, muncie, munciepowerproducts
Mini machines draw ICUEE crowds
excavator1
Why do cylinders fail on an excavator?
AgfaPhoto
What makes a quality hydraulic component?
A look ahead with JARP Industries’ CEO, Kevin Kraft
    • Subscribe!
