Pro-Power cables now in full-reel and cut-to-length for industrial and outdoor use
By Andrew Zistler | January 19, 2016
newarkNewark element14 has expanded its range of cable and wire, cable accessories, marking and labeling from Pro-Power for use in design, education, manufacturing, repair and maintenance.
Highly versatile and flexible, the new range of Pro-Power Tri Rated cables was designed for use in the wiring of electrical cabinets, switch control, relay and instrument panels, and small electrical devices. Available in over 100 colors and sizes, this flexible (Class 5) high temperature, flame-retardant single core and single insulated cable comes with heat resistant PVC sheathing, and can be used in numerous applications globally as it meets three separate standards; British Standards, Underwriters Laboratories (UL) and Canadian Standards Association (CSA).
In addition, a wide range of Pro-Power Coaxial cables are available; these are suited for transmission of radio frequency signals including television aerial connection, transmission of CCTV images and broadband signals.
Newark element 14
newark.com
The post Pro-Power cables now in full-reel and cut-to-length for industrial and outdoor use appeared first on Wire and Cable Tips.
Filed Under: Cables + cable management, Wire & Cable Tips
Tagged With: newarkelement14
