ProEficient Power Amplifiers
By Natasha Townsend | June 20, 2012
ProEficient WCDMA / LTE power amplifier (PA) product family has been optimized for the next generation of 4G devices, by delivering world-class efficiency across all power levels.  These products combine greater talk time in low-power mode with longer data application use in high-power mode.  The result is an enhanced overall user experience and extended battery life across all operating conditions of modern smartphone and tablet devices, as well as lower overall system cost.
The power amplifiers use the company’s exclusive InGaP-Plus technology to achieve efficiency at high and low power modes in order to maximize 4G battery-life without the use of a dc-dc converter.  These power amplifiers are also optimized for use with average power tracking (APT) to further increase efficiency and reduce current consumption at medium and low operating powers.  In addition to efficiency, the power amplifiers deliver linearity to ensure a stable connection for clear voice and high-speed data.
ANADIGICS ProEficient™ PA Family Key Facts and Highlights:
Best-in-Class Performance
  • Industry-leading efficiency at both high and low power modes
  • Low quiescent current
  • Best-in-class linearity (ACLR1)
  • LTE compliant
  • WCDMA, HSPA, and HSPA+ compliant
  • CDMA/EVDO compliant
Outstanding Integration
  • Internal voltage regulation
  • Integrated dc blocks on RF ports
  • RF matching optimized for output power, efficiency, and linearity in a 50-Ohm system
  • 3 mm x 3 mm package
Anadigics
www.anadigics.com/
Power Supply Tips
Filed Under: Power Electronic Tips
schurter
Compact power entry module has side flange mounting option
ABSOPULSE
Three-phase power supplies with active PFC handle 5-kW industrial applications
Sager Electronics to carry SL Power’s 300-W single-output power supplies
wuerth catalog
Catalog covers certified components for automotive electronics
