    • Subscribe!
Encoder Products Co. programmable thru-bore encoder Model 58TP
By Lisa Eitel | June 13, 2017
Encoder Products Company (EPC) now sells the Model 58TP — a 58 mm, thru-bore, programmable encoder.
Contained within the rugged housing of the Model 58TP is an advanced set of electronics that allow the encoder to be programmed for exact application needs. See the unboxing video for an overview.
Programmable CPR, output type, and waveform for the programmable thru-bore encoder
Using EPC’s optional programming module for the Model 58TP, users may select from 6 output types, choose from 32 different waveforms, and program any resolution from 1 to 65,536 CPR — that’s 262,144 counts using 4x quadrature counting.
These programming features allow a single encoder to be configured for multiple applications, enabling one encoder to replace many different part numbers, and providing cost savings on inventory and down-time replacement.
More specifically, the Model 58TP programmable thru-bore encoder offers:
  • Thru-bore or hollow-bore options
  • Programmable waveform — 32 options
  • Programmable output type — 6 different output types
  • Programmable resolution — program any resolution from 1 to 65,536 CPR
  • Standard and metric bore sizes up to 5/8” or 15 mm
  • Multiple flex mount options
  • Seven different connector types
  • Operating temperature option of -40° to 100° C
  • Sealing up to IP67
“The Model 58TP is incredibly versatile,” explains Steve Dilts, Business Development Manager. “Not only are the electronics programmable, but it’s highly configurable mechanically. This is an incredibly versatile thru-bore encoder.”
Applications abound. The Model 58TP is a versatile, cost-effective setup for rotary feedback in many industrial and non-industrial applications, such as: motor control, conveyors, elevator controls, machine control, food processing, process control, robotics, material handling, textile machines and all types of motion control feedback. Almost anywhere a thru-bore or hollow-bore encoder is called for, the Model 58TP will get the job done. See the Model 58TP’s datasheet for product specifications.
[bctt tweet=”Model #58TP #programmable Accu-CoderPro thru-bore encoder for industrial environments” username=”DW_LisaEitel”] This video provides an overview of the Model 58TP’s advanced features, and demonstrates how simple and straight-forward it is to setup and program the Model 58TP:
Encoder Products Company (EPC) is a global leader in the design and manufacture of rotary encoders. EPC‘s Accu-Coder and Accu-CoderPro brands of encoders are used by OEM and MRO customers in nearly every industry. A modern, vertically-integrated 100,000 sq ft facility in Sagle, Idaho, serves as both Global and Americas Division headquarters. EPC products are available through a network of qualified industrial distributors and resellers. For more information, visit www.encoder.com.
You may also like:
  • New EtherNet/IP series of optical encoders from Kuebler
  • Precision magnetic encoders now available with CANopen interface
  • Large area travel XYZ gantry systems from IntelLiDrives
  • CANopen interface on precision magnetic encoders from POSITAL
Filed Under: Encoders (rotary) + resolvers
Lisa Eitel
Lisa Eitel has worked in the motion industry since 2001. Her areas of focus include motors, drives, motion control, power transmission, linear motion, and sensing and feedback technologies. She has a B.S. in Mechanical Engineering and is an inductee of Tau Beta Pi engineering honor society; a member of the Society of Women Engineers; and a judge for the FIRST Robotics Buckeye Regionals. Besides her motioncontroltips.com contributions, she also leads the production of the quarterly motion issues of Design World.
POSITAL’s explosion-proof rotary encoders receive ATEX/IECEx certification
z4636-F5858-Profinet-enc-std-srgb-web
New generation industrial ethernet encoders from Kubler
Sendix M3658 encoder with IO-Link interface
Kubler- A41-product-shot
Kubler A41 draw-wire mechanism with encoder
    • Subscribe!
