Prolift’s Aluminium Gantry Crane with 5000kg lifting capacity
By Editor | June 4, 2012
Prolift Solutions (www.prolift.com.au) has introduced the world’s first lightweight aluminum gantry crane that features a lifting capacity of 5000 kg. This portable aluminum gantry craned is remarkably versatile, mobile, strong and safe to use.
The crane’s A-frame comes with an inbuilt geared hand wheel system, offering users complete control in raising and lowering the crane beam to adjust height according to their preferred setting.
With its integrated stabilizing leg, moving the A-frames around is easier prior to attaching the beam. The Stabilizer Leg mode – which is ideal for use in concrete, flat or tarmac surfaces – enables users to fold down and lock the leg into place, making it easier to move around.
In addition, maneuvering around open and rough ground areas is also made easy by the Wheelbarrow mode. Using this mode allows users to lock the stabilizing leg into position, and then simply folded up when finished.
The crane has been specifically designed with aluminum to deliver unrivalled strength in accord with manual handling guidelines. This lightweight design allows users to position the gantry crane easily and quickly, even without requiring large teams of workers or any additional lifting equipment.
Taking into consideration the practicalities of lifting, the company has provided the gantry crane with a compact design to make it easier to deploy even in restricted spaces. This also makes the gantry crane easy to transport, store and handle.
Prolift Solution’s aluminum gantry crane comes complete with assembly and operation guide, trolley, 4570 mm long beam that is rated to 5000 kg and 360° load rated swivel-locking castor wheel. It also features two A-frames with stabilizing leg and geared wheel elevation system.
Linear Motion Tips
New I/O interface from LINAK expands features, control options
Bosch Rexroth adds high-force model to electromechanical cylinder line
New rail/roller bearing wheel system for high speed, low friction linear motion
Self-lubricating toothed belt axis for clean use in food manufacturing
Going small with 3D printing
