Proportion-Air’s HVC Closed Loop Regulator
By Design World Staff | July 1, 2009
McCordsville, IN ‚– Proportion-Air introduces the HVC, their new cost efficient closed loop regulator. Ideally suited for high volume, low cost, OEM applications requiring closed loop control and high forward and relief flow rates, the HVC can proportionally control pressure ranges up to 150 psig.
The HVC‚’s greatest asset is its flexibility. By utilizing shock and vibration resistant technology inside an IP65 housing the HVC can be mounted nearly anywhere in any orientation. The integral pilot operated regulator allows HVC to operate equally well under flow or static volumes. The internal pressure sensor provides closed loop control that won‚’t change over time. The HVC is incredibly repeatable and accurate.
Proportion-Air
www.proportionair.com
Filed Under: Fluid power, Pneumatic equipment + components, Valves
5 ways to improve packaging machinery with smart pneumatics
Clippard-Cordis-CFC-electronic-Flow-Controller
Cordis flow controller offers high resolution and repeatability in a closed-loop system
Upgrading equipment with solenoids
Clippard Eclipse proportional Valve
Proportional isolation valve offers ultra fine resolution and high repeatability
