ProSense Digital Panel Meters
By PR Editor | January 22, 2020
AutomationDirect ProSense digital panel meters in 1/32 and 1/8 DIN sizes are ac or dc powered and feature IP65-rated meter faces, simple menu-driven pushbutton configuration, and accept a wide variety of input signals. Available outputs include alarm relays, milliamp current, and sensor excitation voltage options.
New process-display options now include (depending on series) ac or dc voltage (20/100/200/600V) and ac or dcamperage (200mA/1A/5A/shunt 50mV/shunt 100mv). Existing display options include analog process signals, load cell, or potentiometer inputs, and temperature inputs in either °F or °C from RTDs or thermocouples. All panels offer selectable decimal point location.
The ProSense DPM2 process meter series is now available with 4-digit (-1999 to 9999) 20mm character height red LED process indicator displays in addition to the existing 4-digit (-9999 to 9999) 14mm red LED displays. The ProSense DPM3 series offers 5-digit tri-color red / green / amber LED process indicator displays.
ProSense digital panel meters from AutomationDirect start at $70.00 and have a 3-year warranty.
AutomationDirect
www.automationdirect.com/digital-panel-meters
Filed Under: Uncategorized
Tagged With: automationdirect
AutomationDirect-Fath
FATH T-Slotted rail hardware from AutomationDirect
eSIGN_3
New eSIGN signal tower from WERMA
May 2022 Issue: Robotic solution speeds up PPE manufacturing process
Saginaw Enviro-Therm Series enclosure air conditioners from AutomationDirect
