HARTING’s new PushPull 20-pin offers enhanced performance and can be loaded with up to 2 A per contact. This is more than enough for camera technology and to power various types of sensors. The joint cable supplying both power and effecting signal transmission also saves additional wiring—and therefore cost—for the customer. The new PushPull 20-pin is HARTING’s answer to rising signal transmission and miniaturisation requirements.
Controllers and control units in an industrial plant are equipped with all types of sensors. They measure temperature, colour, shape, weight, size, pressure and much more. All these sensors must be capable of reliably transmitting their signals to a central control unit concurrently. To make a system more cost-effective and efficient, it makes sense to provide power to as many control measurement instruments over the same cable over which signals are sent.
A signal connector like the new PushPull 20-pole in an industrial environment is robust, easy to handle and can be adapted to customer requirements. HARTING’s new PushPull V4 20-pin version now permits twice as many contacts to be connected within the same physical dimensions – an ideal solution for all combinations of bus and signal data.
HARTING KGaA
www.HARTING.com
The post PushPull 20-pin connector from HARTING operates in harsh environments appeared first on Connector Tips.
Filed Under: Connectors (electrical) • crimp technologies, Connector Tips, MOTION CONTROL
