PWH Series couplings from Lamiflex Couplings
By Mike Santora | September 18, 2018
Lamiflex-lc-pwh-series-couplingPowerflex High Performance couplings are designed to bring high reliability for transmissions in rotary machines.
They are projected to comply with most requirements of the API 671 standard, with respect to assembly. Hubs, guard rings and spacers are manufactured with high alloy steels, while flexible elements are made with high grade stainless steel and the fixture parts undergo rigourous quality control.
As a result of controlled assembly, interference pilot guide and screws with controlled tolerance insure the balancing integrity even after many assemblies.
The flexible coupling must handle two functions: (1) Transmit drive torque to the driven machine and (2) accommodate misalignment of the axles.
High Performance Powerflex couplings are specifically designed to handle these tasks required in critical actions such as: compressors, feeding pumps, injection pumps, generators, gas and vapor turbines and API 671 applications.
Lamiflex Couplings
www.lamiflexcouplings.com
Filed Under: Coupling Tips
Tagged With: lamiflexcoupllings
PTDA onProduct Information Exchange
PTDA Transmissions: Lessons from the Pandemic past can shape the future
Shaft collars and couplings feature wide choice of standard bores
Torque transducers and test machinery use CD couplings from Zero-Max
