Pickering Interfaces is expanding its range of sensor simulators in PXI with the introduction of the 40-265 Strain Gauge Simulator.
Simulating a resistive strain gauge can be a difficult task; the change in resistance value caused by applying stress to a strain gauge is extremely small (typically 0.1%) and requires very fine control of the resistance value. Many users resort to in house methods of simulation which are hard to support and lack traceability, or they have to adapt commercial products that provide very limited performance. Pickering Interfaces has made this much simpler with the introduction of the first commercially available
Strain Gauge Simulator in PXI.
The 40-265 provides 6 channels of strain gauge simulation with high simulation accuracy and performance. Each channel provides a full bridge circuit with very fine resistance control of better than 2 milliohm in one bridge arm, allowing the 40-265 to emulate the operation of a strain gauge bridge circuit. The bridge can be excited by a fixed internal supply or by independent external bridge voltage sources, permitting direct connection to strain gauge measuring systems.
The 40-265 is controlled by simple resistance calls to the variable bridge resistor, and each channel has a stored resistance value at which the bridge is balanced. Users can simply set the bridge to the balance point and then offset the bridge using the very fine control of resistance provided by the 40-265 to simulate applied strain. The bridge output voltage is provided directly to the user connector. The 40-265 permits the user to simulate an open connection for fault simulation.
A calibration port provides a simple way of using a DMM to monitor the channels and to support in house calibration of the strain gauge simulator with an external DMM.
Filed Under: TEST & MEASUREMENT
