QSI’s Operator Interface Terminal
By Design World Staff | December 3, 2008
Salt Lake City, Utah
— Hayward Baker, a geotechnical company, with offices in the US and Canada, has been using QSI’s QTERM-G70 for their applications in PƒÂ©ribonka, Quebec where temperatures range from -20 to 24 ‚°C (-4 to 75 ‚°F). Additional strains to hardware are the extreme environmental conditions including rain, snow and wind.
The QTERM-G70 seen here is monitoring various flow rates, pressures, temperatures and consistencies. This particular unit meets NEMA-4 sealing requirements and is temperature rated from -30 to 80oC.
“With rigorous conditions like those in PƒÂ©ribonka, the QTERM-G70 was put to the test and met the required demands for the application,” said QSI’s Senior Sales Engineer Glen Johnson. “Our in-house environmental testing ensures that all units will perform under extreme conditions. The G70 produced for Hayward Baker meets NEMA-4 sealing requirements and is temperature rated from -30 to 80 ‚°C (-22 to 176 ‚°F).”
The QTERM-G70 is designed to withstand the shock and vibration of such a harsh environment and this unique mountings system.
“For the PƒÂ©ribonka project, the QTERM-G70 replaces dated gauges and manual processes that were being relied on to get accurate data and make minute, yet pivotal changes with monitoring various flow rates, pressures, temperatures and consistencies,” said Fritz Achhorner, Corporate Engineer at Hayward Baker.
This QTERM-G70 uses an enhanced TFT color display, which is rated at 600 nit, providing a readable display in bright sunlight and snow conditions.
QSI Corporation, manufacturer of rugged terminals since 1984, serves various applications in the geotechnical and oil and gas industries, including concrete pumping, coiled tubing, pumping stations and data acquisition. QSI performs rigorous environmental testing on all terminals including operating/storage temperature, humidity, thermal shock, sealing, operating/storage vibration, physical shock, physical drop, ESD, dust, windblown rain and dust, power-line transients, EMI, EMC, key press and acceptance burn-in.
The operator’s control panel is boom mounted to provide flexible operation from the best vantage point. This is just another cold day in December in Peribonka, where no matter what the weather is like, the work still gets done.
“The success of the QTERM-G70 under these conditions opens up additional geotechnical applications for QSI,” said Glen Johnson. “Our terminals are designed to perform under strenuous conditions. This has a direct impact on our end users bottom line as they do not experience downtown due to hardware issues.”
www.qsicorp.com
Filed Under: Displays • HMIs • operator interfaces • monitors
