Smart lidar targets collision avoidance, smart navigation for mobile robots, port automation, warehouse logistics apps
By Lee Teschler | November 16, 2021
The new M1 Edge 2D LiDAR sensors paired with Quanergy’s QORTEX Aware perception software is an integrated software and hardware solution designed to automatically collect, analyze, and interpret LiDAR point cloud data for a wide variety of industrial applications without additional programming.
The M1 Edge smart solution includes compact, lightweight LiDAR sensors with extremely accurate sensing capabilities up to 200 m, broad 360° coverage, and an industry-leading angular resolution of quanergy0.033° for best-in-class measurement. These robust sensors are rated up to IP67 for harsh environments and perform reliably in any lighting or weather condition, providing up to 60,000 hours mean time between failure (MTBF) and delivering a lower total cost of ownership (TCO) than competing solutions.
M1 Edge integrates the sensor with on-board QORTEX Aware smart perception software to monitor user-defined detection zones and trigger an alarm on the sensor’s digital output if there is any activity within the zones. Users can create up to eight pre-configured evaluation fields, each with up to three detection zones, where the evaluation field is selected via the sensor’s digital output.
“After evaluating Quanergy’s latest product M1 Edge, we are excited to deploy this low cost, 2D industrial sensor. It solves real world industrial sensing applications by combining simple to use software vision tools with a high resolution LiDAR array. We know of no other outdoor rated sensor that has both the range and resolution of the M1 Edge,” said Neil Jacques, President of IPTech1.
M1 Edge enables reliable collision avoidance and smart navigation for mobile equipment. When mounted on an AGV or AMR, the sensor monitors the surrounding area, flagging potential dangers and obstacles in the vehicle’s path. The detection zones being monitored can dynamically change based on the vehicle’s movement.
Furthermore, M1 Edge provides accurate detection and measurement for stationary and dynamic applications that require simple alerting when an object enters a monitored area. For example, in industrial applications, M1 Edge enables reliable monitoring for level and height sensing applications, including tank level monitoring, object stacking, fill level detection and more.
“LiDAR has become instrumental in increasing efficiency by solving tough sensing challenges faced by industrial customers—thanks to unmatched reliability and accuracy,” said Tony Rigoni, Director of Industrial Markets. “It’s quick to setup, delivers unmatched performance and competitively priced which makes the M1 Edge LiDAR solution deployable to even a broader range of industrial applications.”
Quanergy Systems, Inc., 433 Lakeside Dr., Sunnyvale, CA 94085, (408) 245-9500, www.quanergy.com
You may also like:
  • PCB mills
  • Did you foresee Facebook?
  • 9-11 truthers
    The WTC collapse after two decades
  • scilab
    The top ten free engineering math software packages
  • don't worry about EV fires
    Don’t worry about EV fires
Filed Under: TECHNOLOGIES + PRODUCTS, Sensors (position + other), Sensors (proximity)
Tagged With: Quanergy
Screenshot 2022-05-10 at 12.00.35 PM
FAULHABER: Everything under control
Rockwell Automation offers new online capabilities with industrial automation software
NYE adds Vishay Miniature Position Sensor to product lineup
