PALATINE, IL – Lumex announces the global launch of its QuasarBrite High-Temperature Seven-Segment numeric LED Display technology capable of providing bright, crisp display performance in market-leading temperature ranges up to 105°C.
The new high-temp seven-segment ¼ watt LED displays are available in sizes from 0.28 inch to 4 inch character height and come with complementary integration support from Lumex´s team of Technical Design Specialists.
QuasarBrite High-Temperature Seven-Segment LED Displays are compatible with standard drivers and are ideal for a wide range of applications that require performance in extreme heat conditions including:
• industrial control device technology (oil field and gas flow metering, drive control displays for heavy motor control technologies and welding assembly line equipment);
• military applications (including aircraft, ground vehicles, GPS and walkie-talkie systems)
• appliances (including displays on ovens, microwaves, and dishwashers)
QuasarBrite High-T emperature Seven-Segment LED Displays are available in any color and come with complimentary integration support. Lumex´s team of Technical Design Specialists help customers integrate the new QuasarBrite High-Temperature Seven-Segment LED Displays with switches, resistors, IC driver chips, capacitors and other technologies required to create a complete interface board solution. This complimentary integration support generates cost savings, speeds time to market and reduces opportunity for product failure due to integration issues.
Lumex
www.lumex.com
Filed Under: Lights • signal lamps • indicators, ELECTRONICS • ELECTRICAL
