Gates Quick-Lok™ threadless couplings eliminate hydraulic leaks and increase assembly line productivity.
Their innovative design makes them quick to connect in compact, power-intensive machines, and they have a big impact on your operations by:
• Eliminating leaks for fewer warranty claims
• Requiring no special servicing tools
• Increasing assembly line productivity
• Lowering cost of ownership
Though threadless connectors sometimes have a reputation as expensive, niche products for limited applications, Gates is changing that. Quick-Lok assemblies are replacing threaded couplings in a wide range of applications. Analyses have shown that by reducing installation and warranty costs, a Quick-Lok assembly dramatically lowers total OEM cost of ownership, making it the ideal solution.
Quick-Lok High connectors are designed to replace threaded connection in up to 70% of high-pressure hydraulic equipment applications. Suited for up to 1 and 2-wire braid construction hoses such as Gates MegaSys® Wire Braid Hose, QLH connectors are available in —4 to —16 sizes in multiple configurations for both the coupling and the adapter.
Whether you work in construction, agriculture, truck & bus, forestry, mining or manufacturing, learn more about the many advantages of Quick-Lok™ threadless couplings.
Quick-Lok threadless couplings are pushed into place quickly and simply by hand.
For more information or to receive your free design guide, please contact Gates Corporation.
www.gates.com
Filed Under: Hydraulic equipment + components, Couplings, FLUID POWER
