    • Subscribe!
Quick Release Set Collars from J.W. Winco
By Laura Carrabine Senior Editor | May 22, 2012
J.W. Winco, Inc. now offers GN 704 Quick Release Set Collars.
Parts that need to be secured on stationary or rotating shafts can be easily adjusted with these set collars. Unlike thrust bolts or clamping screws, they generate locking force on the shaft via a cam lever. This quick release design allows the collars to be set or adjusted rapidly and without tools, and the aluminum design results in low mass inertia values.
Quick-Release-Set-Collars
These RoHS compliant set collars feature a body of black anodized aluminum, and a lever of yellow anodized aluminum. They are available in both inch and metric sizes for a variety of shaft diameters. The slim profile allows for optimal use of space on the shaft.
J.W. Winco
www.jwwinco.com
Filed Under: Collars • locking devices, Fastening + joining • locks • latches • pins
Southco introduces stylish corrosion-resistant stainless steel positioning hinge
C2 lever latch offers auto-relock functionality and modern appearance
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
    • Subscribe!
