R325P Stepper Driver from Lin Engineering
By Stacy Combest | March 1, 2013
Lin Engineering announces the release of the new R325P; an updated version of the popular R325 stepper driver product. Combining compact size with high performance, the R325P can be utilized with stepper motors of many shapes and sizes.
The R325P microstepping driver is capable of output currents ranging from 0.3 to 3.0 amps peak while handling +12 to 48VDC of input voltage. With selectable step resolutions from Full stepping to 256x microstepping, the R325P stepper driver is capable of stepping a typical 1.8 degree motor over 51,000 steps per revolution! The R325P also boasts current reduction capability with adjustable current and timeout settings and three optically isolated inputs and one optically isolated control output that can be used for step, direction, disable/enable, and fault detection. One of the biggest advantages of the R325P is its ease of use; with on-board DIP switches, there is no need to connect this device to a computer making set-up quick and simple.
For those users requiring an Indexer, the R325PE is also available. The R325PE can be configured via RS485 and comes with software, LinControl, at no cost. Along with the capability of various velocity moves, the R325PE also has an encoder input.
Lin Engineering
www.linengineering.com
Motion Control Tips
Filed Under: Motion Control Tips, Drives (stepper) + amplifiers
Tagged With: linengineering
New gearboxes for electric motors in mobile machines
Leading motion-control and actuation options for robotics
Basics of wave and cycloidal gearing for robotics and servo designs
New micro servo-drive system for extra-low-voltage manufacturing applications
