RAFI E-BOX now with M12 connector
By Anna Casey | June 28, 2018
RAFI’s E-BOX, a particularly slim housing for one or two RAFIX 22 FS+ control devices, is now also available as a pre-configured unit with an M12 connector. No wiring is required for this ready-to-use solution that provides emergency stop buttons or simple ON/OFF switching functions at remote locations. E-BOX features a very compact size of merely 109 x 40 x 27 mm and is suitable for mounting on 40-mm profile rails or, for instance, on protective barriers. A single screw fixes the mounting clip in the profile rail groove. Users can then simply attach the E-BOX housing – it clicks and sticks.
E-BOX M12 is available as a 4-pole or 8-pole version with illuminated pushbuttons. The pre-configured range currently comprises models with an emergency stop or a pushbutton, or both, or with two pushbuttons (1 NC, 1 NO). The housing tops for the emergency-stop versions are colored signal yellow, the pushbutton ones are gray. Different pushbutton designs are available for various uses: ON/OFF switches with red and green blinds (optionally flat or raised), gray pushbuttons with arrows for lifting and lowering movements. Users can individually mark the button of the single-pushbutton E-BOX model with RAFI’s FLEXLAB labeling system. The new E-BOX M12 housings feature IP65 ingress protection and a -25 °C to +70 °C ambient temperature range.
For a sample or volume pricing requirements, contact RAFI-USA at [email protected]
For more information, visit:
http://www.rafi.de/en/products/components/rafix-control-components/e-box/
RAFI
www.rafi.de
Tagged With: rafi
