RAILTEC-BUS System For DIN Rail Enclosures
By Megan Hollis | June 1, 2014
OKW’s new RAILTEC-BUS system makes it quick and easy to link DIN rail enclosures that share the same power and signal connections.
Picture of DIN Rail Enclosures
RAILTEC-BUS speeds up the installation of DIN rail boxes in the same equipment cabinet. It is designed for 7.5 mm high top hat TH35 DIN rail assemblies.
The modular system consists of the bus support rail (moulded in PA); the bus PCB with five copper conductors (maximum 63 V, 5 A); the rail cover (PA) to stop damage and short circuits; the PCB/bus connection block (PA) with PCB pins and five gold-plated connection springs; the end caps (left and right hand).
Two bus lengths are available – 250 mm and 500 mm. Prices for a full system assembly start at £65.
RAILTEC-BUS has been designed to be fully compatible with OKW’s existing RAILTEC-B and RAILTEC-C ranges of DIN rail enclosures.
RAILTEC-B DIN rail enclosures are now available in a new size – 3 modules – complementing the existing 2, 4, 6, 9 and 12 module sizes. Choose from six different versions and three formats: ventilated, non-ventilated or open.
RAILTEC-C also offers a wide range of options including two formats (open on one or both sides) plus accessories: panels, lids, terminals and a rail adapter (which converts the standard rail clip to suit G32 and TH15 rails).
OKW Enclosures LTD.
www.okw.co.uk
Filed Under: Linear motion • slides
Tagged With: okwenclosuresltd
LM76-SPEED DEMON EL300 4x5x300
LM76 SPEED DEMON EL300 for high speed, low friction, smooth linear motion
Stainless steel linear guide rail systems
LWLF2_FAM
IKO’s New LWLF2 Miniature Linear Guides
igus introduces self-lubricating toothed belt axis designed for clean use in food technology
