Raise3D, a global provider of additive manufacturing solutions for SMEs and LSEs, announces a breakthrough in FFF professional 3D Printing, with the launch of a Hyper Speed Upgrade Kit (HUK3) for the Pro3 Series 3D printers, their flagship professional product.
The gradual adoption of FFF 3D printing has shown that, regardless of its speed, it can be the most competitive manufacturing method to produce prototypes, to customize products, to meet individual’s needs, and to carry out small batch production.
Until today, however, it was common to see 3D printing only as a complement to traditional manufacturing methods, either because of its speed when considering professional solutions, or its high price if industrial level solutions are taken into account.
Raise3D is thrilled to announce a breakthrough technology that challenges all the existing limitations of FFF 3D Printing. It’s a breakthrough, it’s revolutionary, it’s a game-changer, it’s literally the next level for professional FFF 3D Printing, and Raise3D is truly excited about it!
Technology
In the wake of the development of high-speed for the RMF500, Raise3D managed to apply its learnings to its Pro3 series printers, achieving a speed 3.8 times faster than the current best professional printer available in the market.
The challenge was never to just instruct an FFF printer to print at a higher speed. Telling an FFF 3D printer to print at high speed is quite simple, and most manufacturers and users have tried it at some point. The challenge was to be able to do so in while keeping the same quality of layer adhesion and surface finish, in addition to the structural stability of the whole printer.
Raise3D can proudly announce that its R&D team has achieved this goal, initially for its Pro3 series dual extrusion 3D printer, for which the whole Raise3D’s ecosystem – hardware, software, and filament – had to be adapted.
The Pro3 Series’ strong and stable frame allows the printer to maintain high dimensional accuracy and excellent surface quality while running at extremely high acceleration and high speeds. Also, the Pro3’s advanced onboard processors allowed Raise3D’s R&D team to fully unleash the power of innovative motion planning techniques, and process over 600,000 steps per second to implement an active vibration cancellation algorithm.
The hyper speed solution is partially protected by Raise3D’s existing patents.
Competitive arena
Raise3D’s analysis of the current competitive arena in the professional market is that with the Hyper Speed Upgrade Kit, the Pro3 Series’ current lead in terms of technology becomes even clearer, and besides the already existing overall quality, it will undoubtedly be the fastest professional dual- extrusion printer on the market for some years.
This represents an opportunity for Raise3D to push the FFF market to the next level and to substantially increase its current customer base, which is needed in order to fulfill its ambitious development plan. For these reasons, it has been decided to make the Hyper Speed Upgrade Kit for the Pro3 Series, or HUK3 for short, available at an exceptionally affordable price until the end of the year.
Performance
The results reached with the installation of the HUK3 on the Pro3 series, and the use of filaments from the high-speed line of filaments, are impressive and make it clearly stand out from all other professional printers:
Productivity | Volume
Speed |
Shell
Speed |
Infill Speed | Acceleration | Weight
Consumption |
Current Professional
Market best printers |
1x | 6mm3/s | 25 to
60mm/s |
80 to
100mm/s |
500 to
1,500mm/s2 |
100 to
200g per day |
Pro3 Series with full
HUK3 installation |
3 to 5× | 28mm3/s | 120 to
250mm/s |
200 to
350mm/s |
5000 to
10,000mm/s2 |
600 to
1,000g per day |
*All results with 0.4mm nozzle and 0.2 mm layer height.
Edward Feng, Raise3D’s global CEO, said: “The results we’ve achieved with this technology breakthrough are truly remarkable, far better than we could anticipate, and makes us feel confident it will be a milestone, not only for Raise3D, but even for the whole FFF-based3D printing industry.” He added: “Our competitive superiority at a technological level has been increasingly recognized over the last years. With the HUK3 allowing customers’ ROI to multiply by more than 3 times, we now want to reach more than 3 times the customers we have so far, and have so decided to offer, until the end of the year, an exceptional price of almost 1/3 lower than the retail price planned for 2023.”
Filaments available
One of the challenges Raise3D faced while pushing for higher speed was the limitation coming from the filaments’ flowability.
In FFF, as it is known, the deposited material lines are fused by the residual heat of the material and the pressure of the moving nozzle. However, when the printing speed increases by a factor of 4, the filament has very short time to melt from solid to a molten state, leaving the extruded material in a semi-molten state, with a hot shell and cold core, which can cause nozzle clogging and poor bonding quality between layers. Raise3D and their partners worked together to solve this challenge and is now launching two new filament lines for high-speed printing: the Hyper Speed and the Hyper Core.
The Hyper Speed is comprised of the more widespread filaments, while the Hyper Core is oriented towards more professional and industrial filaments, such as fiber-reinforced materials for industrial and end-use parts production and heavy-duty applications such as tooling, jigs & fixtures.
Both filament lines are optimized with balanced molecular weight and flowability, which allows them to have an excellent interlayer bonding quality and Z-direction strength, a smooth surface quality, and absolutely zero warpage, making it perfectly suitable for many functional parts.
The Hyper Speed line will initially have available PLA and ABS, but other materials, like PETG, PC, ASA, ESD-safe, among others, are already in the pipeline to be released.
During 2023, the Hyper Core line will also launch its first filament, PPA CF, which is a carbon fiber- reinforced composite filament with superior heat resistance, strength, and stiffness.
To enhance the number of materials available for their customers, Raise3D will now invite filament manufacturers to join a specific new stage of their Open Filament Program (OFP), focused on high speed filaments.
Additive productivity, ROI, and batch size
The application of the Hyper Speed Upgrade Kit to Pro3 series printers allows it to achieve a speed on average 3.8 times faster than the current best professional printer available in the market. From
Raise3D’s calculations, the boost in productivity is such that 3D printing service providers may be able to pay back their investment in Pro3 series printers in a matter of weeks.
The increased productivity shall also have a substantial impact on traditional manufacturing processes, like injection molding and CNC, in particular when the part produced may be subject to frequent or regular design changes.
With an increased productivity of over 3 times, the all-in cost of a Pro3 series printer becomes extremely affordable when compared to the usual price of even just the tooling required in other manufacturing processes. This, together with the full flexibility provided by additive manufacturing, now makes FFF 3D printing very competitive as a manufacturing method, even for sizeable batches and will make print farms / print factories more and more common.
Pricing
The HUK3 includes software upgrades, 2 high-flowrate Pro3 hot ends, a smart auto frequency calibrator, a spool of Hyper Speed PLA, and a spool of Hyper Speed ABS.
The prices of the HUK3 and the filaments for US and EU are listed below. In other territories, prices may differ.
Product (only for Pro3 Series) | Retail Price (USD & EUR) |
Hyper Speed Upgrade Full Kit | 999.00 |
Hyper Speed PLA Filament 1kg | 36.00 |
Hyper Speed ABS Filament 1kg | 36.00 |
For customers who already own Pro3 series printer(s) or will purchase it and the HUK3 until December 31st, 2022, the following exceptional offer for HUK3 will apply:
Hyper Speed Upgrade Full Kit | 699.00 |
Future
The Hyper Speed will also be available for the RMF500, the industrial printer developed for Fast Production of Large composite End-use Parts, and Raise3D is now also working to make it available for the other printers in their portfolio that have the same mechanics as the Pro3 series.
Filed Under: Make Parts Fast
