The Cortet Z10 Range Extender (CGW-Z-010) is for use in various wireless sensor network (WSN), machine-to-machine (M2M), and Internet of Things (IoT) applications. The Z10 Range Extender has been optimized for RF performance, providing industry-leading range within a compact and attractive design that is ideal for any project.
The Cortet Z10 Range Extender is a reliable, secure, and easy to install way to extend the range and/or capacity of a zigbee network within large facilities or facilities with a poor RF environment. The Z10 Range Extender is capable of distances greater than 325 feet (100M) in interior environments. It’s built in software makes it easy to set up the extender and commission the device into a zigbee network.
The Z10 is an HA 1.2 compliant repeater and range extender for a zigbee network. The Z10 requires a zigbee Coordinator such as the Cortet E100 Gateway. The Z10 Range Extender is also REACH and ROHS certified and has been tested to work well with a wide range of industrial lighting controllers, luminaires, lamps and other accessories from companies like Leviton, ILLUMRA and Magnitude.
Key Technical Features
Input AC Voltage 100-240 VAC, 50/60 Hz
Maximum Current Drain 0.07A
Operating Temperature Range -20 to 40C [-4 to 104F]
Product Dimensions when installed – 60.3mm x 51.0mm x 42.1mm [2.37 in x 2.00 in x 1.66 in]
AC input IEC Type A, ungrounded, non-polarized
