RathGibson Makes the Titanium Connection
By atesmeh | October 4, 2013
RathGibson connects with the power generation and chemical processing industries by offering exceptionally-engineered Titanium tubing for heat exchangers, condensers, and chemical processing applications. Manufactured at the North Branch facility, this tubing has the corrosion resistance and exceptional strength-to-weight ratio that makes it the ideal choice for operations in harsh environments, including seawater.
RathGibson offers Titanium Grade 2 in wall thicknesses from 0.020″ (0.51 mm) to 0.083″ (2.11 mm) with outer diameter sizes starting at 0.5″ (12.7 mm) and going up to 1.5″ (38.1 mm). This light-walled tubing not only optimizes heat exchange, but also reduces the overall operating costs. A thin oxide film over the tube’s surface maximizes corrosion resistance. All tubes are ASTM B338 and ASME SB338 certified with excellent weldability for more flexible designs.
“RathGibson has always and will continue to produce high-caliber tubing that meets our customers’ ever-changing needs,” said Greg Jones, Director, CPI Sales. “Our extensive experience with the power generation and chemical processing industries has led us to the realization that many situations require the strength and durability that only Titanium can provide.”
RathGibson, a PCC Energy Group Company, is a worldwide manufacturer of precision engineered straight lengths, coil, and U-Bend tubing for diverse industries such as power generation, renewable, oil and gas, petrochemical, chemical, food and dairy, beverage, pharmaceutical, and general commercial.
