Elmo Motion Control releases a new addition to the Whistle family of servo drives, the Solo Whistle. The Solo Whistle is a ready-to-use integrated solution designed to simply and efficiently connect Elmo's Whistle Servo Drive directly to the application. The solution consists of the Whistle plus a connection interface which either eliminates or reduces development time and resources when designing an application's PCB board. The Solo Whistle can be easily set up and tuned using Elmo's Composer software tools.
Highlights of the Solo Whistle include:
• Advanced motion control capabilities in a highly compact package
• Supports a wide variety of feedbacks
• High level programming environment
• Highest power density incorporated with Elmo’s SimplIQ servo core with motionrich
capabilities
• Mountable anywhere-in the motor, in the machine, on the load, attached to the moving part, etc.
Filed Under: Drives (servo) + amplifiers, Motion control • motor controls
