March 2007, Depew, NY, USA – The IMI Sensors division of PCB Piezotronics has announced the release of the Model 649A01 Reciprocating Machinery Protector (RMP), which utilizes the next generation of impact monitoring technology. This two-wire, loop-powered, 4-20 mA transmitter detects impacts from mechanical shock events, which typically occur in or near a machine’s cylinder assembly. This technology is particularly effective on reciprocating machinery where these high frequency impacts are often overlooked, or when trending overall vibration levels. The hermetically sealed design can be easily interfaced with existing alarm, control, and monitoring systems such as PLC’s, DCS’s, and SCADA systems.
The field programmable features of the RMP allow users to customize each installation point and tailor the output to suit their application. This includes variable set points and alarm levels for optimum performance. The RMP detects common reciprocating compressor faults such as loose or broken bolts, cracked connecting rods, and scoring in the cylinder.
For detailed product specifications, drawings or additional information, visit www.pcb.com.
PCB Piezotronics, Inc.
3425 Walden Avenue
Depew, New York 14043-2495
USA Tel: 800-828-8840 (toll-free)
24-hour “SensorLine”: 716-684-0001
USA Fax: 716-684-0987
International Fax: 716-684-4703
E-mail: [email protected]
Web: www.pcb.com
About PCB
PCB Piezotronics was founded in 1967 as a manufacturer of piezoelectric quartz sensors, accelerometers, and associated electronics for the measurement of dynamic pressure, force, and vibration. The unique expertise of the company was the incorporation of microelectronic signal conditioning circuitry within these sensors to make them easier to use and more environmentally compatible. These ICP sensors gained wide popularity and became the foundation for the company’s success.
:: Design World ::
Filed Under: Factory automation, Automotive, Off highway • construction • agriculture, MECHANICAL POWER TRANSMISSION, Motion control • motor controls, Shocks + vibration control • gas springs
