Binder USA LP has expanded its M12-A connector portfolio with two new rectangular flange connectors. Designed for today’s advanced automation technology, the connectors provide new options for sensor and actuator applications.
The M12-A connectors include a stranded-wire version with 20 or 26 mm rectangular housing, and a solder version with 20 mm housing. (The stranded-wire 26 mm version uses the same drilling template as the M16, allowing users to switch to M12 without changing the existing housing.) For simple and reliable installation, binder used a two-part approach consisting of the housing and the contact holder, allowing the coding nose of the contact holder to be positioned in increments of 45°.
Highlights include:
- Available with 4,5, or 8 pins
- Protection rating: IP68
- Operational temperature range: -40° to 85 °C
- Rated voltage: 250 V
- Rated current: 4 A (3A UL)
- Contact plating: Au (gold)
About Binder USA LP
www.binder-connector.us
Filed Under: Connector Tips
