Red Lion Controls Releases Latest HMI with the Graphite Series
By Editor | July 16, 2013
Red Lion Controls announced the release of its newest generation of Human Machine Interfaces (HMI) – the Graphite series of advanced operator interface panels. With all cast-aluminum construction, the Graphite series provides a rugged HMI solution to combine a wide range of versatile plug-in modules with protocol conversion, data logging and web-based monitoring and control.
Red Lion’s Graphite series allows customers to easily connect, monitor and control their process in industries that include manufacturing, oil and gas, and water/wastewater. The series’ range of plug-in modules enables customers to easily create a solution for today, with an option to expand to meet changing business requirements. Further, organizations will realize a reduction in development and commissioning times over traditional systems that use an HMI paired with separate I/O, PLCs and other controllers.
Graphite-HMI-Series
Graphite HMIs are available in eight different models, in sizes ranging from 7” to 15”, with sleek bezels that provide a relatively large display given their overall dimension. Both the 7” and 10” HMIs are available as sunlight visible models. Combined with Graphite’s rugged packaging, these models are ideal for harsh outdoor environments.
Offering a built-in web server, Graphite HMIs enable users to monitor and control their application via PCs, tablets or smartphones. SMS text-messaging and email alerts provide early warning of process issues, which helps to avoid costly downtime. In addition, its built-in protocol converter allows programmers to select 13 or more simultaneous protocols from a list of over 250 to seamlessly integrate disparate devices such as PLCs, drives, barcode readers and panel meters.
The new HMIs are supported by Red Lion’s Crimson 3.0 software, which is included at no extra cost. Crimson 3.0 makes it fast and easy to configure protocols, define data tags, set up sophisticated applications and create an attractive user interface. Designed for ease of use, Crimson allows customers to cost-effectively standardize on one HMI for all of their machines, regardless of the PLC or drive manufacturer used.
Red Lion
www.redlion.net
Filed Under: Displays • HMIs • operator interfaces • monitors
Tagged With: RedLion
