The S2 M Ecoline crimper from Uniflex is the ideal device for the on-site repair of hydraulic hoses in construction and agricultural machinery. The manually operated device weighs only 30 kg and allows for fast and safe establishment of hose connections up to 1 in. (for 2-part fittings) or 1 ¼ in. (for single-part fittings).
Thanks to the greaseless slide bearing technology and the sturdy frame, crimping with the S2 M Ecoline is particularly safe, clean and convenient. When operated in high-gear mode, the new two-stage pump of the S2 M Ecoline H range is particularly efficient, so that tasks can be completed three times faster than with conventional pumps. When not in use, simply push in the telescopic lever, so that the device takes up even less space when stowed away.
As is the case with all hydraulic crimpers from Uniflex, the S2 M Ecoline H comes with a manufacturer warranty of two years.
Uniflex-Hydraulik GmbH
www.uniflex.de
The post Reduce machine downtime with the S2 M Ecoline hose crimper appeared first on Hose Assembly Tips.
Filed Under: Hose Assembly Tips, Connectors (electrical) • crimp technologies
