Reduction Factor 1 Sensors with IO-Link combine benefits of two technologies
By News Staff | April 5, 2019
Pepperl+Fuchs has extended its portfolio to include reduction factor 1 sensors with IO-Link for even more flexibility, additional features, and diagnostic options.
Standard inductive sensors detect non-ferrous metal targets at reduced switching distances. Reduction factors can vary from one metal to another. Pepperl+Fuchs’ reduction factor 1 sensors circumvent this issue and unify switching distances for all types of metals.
Predictive maintenance made easy
Reduction factor 1 sensors with IO-Link are easy to configure via the PLC while data control functions ensure automated reconfiguration through an IO-Link master in case a device needs to be replaced. The sensors suit applications with mechanical tolerances that would lead to detection issues with standard sensors. With the IO-Link sensors’ stability alarm, the system can be triggered in the event that the activation target drifts outside the assured operating distance. This function makes commissioning easier with a flashing integrated LED for visual indication of assured setup and makes predictive maintenance possible. If an activation target drifts from the assured operating distance due to mechanical influences, the intelligent sensor detects this condition, the integrated LED flashes, and the signal is automatically transferred to the control system. This is how intelligent sensing via IO-Link and the control system is used for smart automation and diagnostics in the modern application era.
If necessary, a reduction factor 1 sensor can serve as a temperature indicator that shows whether it is operating within the specified temperature range, or whether it is exposed to a critically high temperature. These indicators provide early detection of temperature increases before the sensor or other sensitive system components, like those found in paint shops or foundries, may be damaged. With the help of the stability alarm and the temperature indicator, pre-failure information is continuously communicated so maintenance can be carried out prior to sensor fault.
Weld-immune sensors are used for especially harsh industrial environments such as weld cell applications in the automotive industry. They are rugged and resistant to interference from magnetic fields during electric welding, weld spatter, and other such influences. Stainless steel versions withstand aggressive cleaning agents and suit demanding applications, i.e., in the food industry or in chemical and pharmaceutical plants.
In window mode, the sensor activates between two switch points and checks whether the object is located inside the defined switching window or is too close to the sensor and could possibly cause damage. In addition, the output signal extension improves detection reliability. This pulse extension is especially helpful in applications with fast-moving targets.
Another innovation is the possibility of switching between normally open and normally closed or between a standard and double switching distance. Pre-configured as double operating distance, this can be switched over to standard switching distance via IO-Link-four sensors are no longer necessary. With these features and the fact that you can get identical switching distances for all metals, users can reduce procurement, administration, and storage costs.
Highlights of the Reduction Factor 1 Sensors with IO-Link:
–Complete IO-Link solution from a single source: sensors, masters, and infrastructure
–Smart maintenance via stability alarm and temperature indicator
–Flexible—a broad portfolio of sensors with identical switching distance, regardless of a target’s material
–Rugged, weld-immune sensors with IP68/IP69K protection for harsh industrial environments
Available in a full range of technologies: inductive, photoelectric, and ultrasonic
Pepperl+Fuchs
www.pepperl-fuchs.com
Filed Under: MOTION CONTROL, SENSORS
Tagged With: Pepperl+Fuchs
