Refrigerant-based rack and row enclosures keep IT equipment cool
By Andrew Zistler | March 9, 2016
lcpRittal Corporation has introduced a new refrigerant-based rack and row cooling solution, known as LCP DX, for heat removal of critical IT components.
The DX line is available in two models, as a Rack or In-line solution, and is ideal for small- to medium-sized data centers or computer rooms that need an efficient and cost-effective way to remove heat from IT equipment without the use of water or glycol.
The Rittal Rack LCP DX delivers superior precision-based heat removal, as it puts the cooling only where needed to protect valuable IT equipment while minimizing energy costs. Furthermore, the Rittal LCP DX solution is a complete unified solution that includes air-flow optimized enclosures with includes baffles and blanking panels.
The LCP DX achieves maximum energy efficiency through its intelligent CMC III SNMP-based management system, which monitors heat conditions and enables fans to continually deliver the required cooling by means of heat exchangers and fans.
Rittal Corporation
rittalenclosures.com
Filed Under: Cabinets • enclosures • control panels • DIN rail, ELECTRONICS • ELECTRICAL
Tagged With: rittal
