Compact general purpose relays available in new bifurcated contact models are great as input devices for a variety of controllers including PLCs and Smart Relays used in the micro processing industry.
RJ22 relays are available with low signal switching bifurcated contacts for increased contact reliability, reduced contact bounce and switching low currents and voltages (dry circuits).These models have a maximum contact rating of 1amp at 250V AC, while maintaining a minimum switching load of 100uA 1V DC, allowing you to use this relay for dry circuit switching needs. With the shortest width on the market RJ bifurcated relays are durable, compact and available with plug-in or PCB terminals.
Plug-in terminal relays have a non-polarized green LED indicator available (except on the simple type), utilizing IDEC’s unique light-guide structure. Diode, reverse polarity diode, and RC circuits are also available with peak inverse voltages of 1000V.
Like the rest of the RJ family, RJ22 PCB bifurcated relays have been manufactured with attention to even the smallest details. Using our automated manufacturing technologies, an innovative design was utilized in the internal construction of moving parts ensuring the highest-quality, reliable relays. This includes a unique return spring structure eliminating unnecessary weak points, allowing for increased electrical conductivity and longer service life. Both DPDT and DPST-NO contact configuration types are available in a flux-tight structure.
RJ Plug-in and PCB Terminal relays (with bifurcated contacts) are UL recognized, CSA certified, VDE approved and CE marked. Correlating 2-pole sockets include multiple features for ease-of-use and can be DIN rail, panel or PCB mounted.
IDEC
www.IDEC.com/relays
Filed Under: Electronics • electrical, Relays
The RJ22S Bifurcated relays are all well and good, but they are impossible to buy!! We have a customer who is unwilling to accept any substitute and there are still thousands of these on backorder from last year, plus we’ll need thousands more this year! It’s ridiculous!!!!
