Rated IP 68 and NEMA 4X, Remke Stainless Steel Liquidtight Connectors provide excellent corrosion resistance, plus the strength of stainless steel for the highest levels of endurance. In corrosive environments standard metal fittings will corrode resulting in frequent replacements, downtime and increased costs. But using Remke Stainless Steel Liquidtight Connectors solves those problems.
Features of Remke Stainless Steel Liquidtight Connectors include:
• Type 304 stainless steel body and ferrule
• Available in straight and 90 degree, 3/8” to 1” in stock with larger sizes available
• Standard NPT Threads with Pg and Metric available upon request
• Nylon insulated throat
• Viton O-Ring standard (optional from other manufacturers)
• UL Listed and CSA Certified
• Installs quickly with low torque requirements
For use in wet or dry locations, Remke Stainless Steel Liquidtight Connectors seal against dust, dirt, oil, water, chemicals and other corrosive elements. They are ideally suited for OEM and MRO applications known for their corrosive and abusive environments including:
• Food & Beverage Processing
• Petrochemical and Chemical Processing
• Pulp & Paper Mills
• Wastewater Treatment
• Heavy-duty electrical motors, generators and transformers
• Offshore Oil Rigs & Platforms
• Portable equipment
• Machine Tool building
Filed Under: Fastening + joining, Connectors (electrical) • crimp technologies
