Reusable Air Filter Frames
By Design World Staff | July 28, 2008
SAUGET, Ill. ‚– Universal Air Filter has developed a reusable clamshell or thin envelope air filter frame that allows customers to replace only the air filter media, resulting in lower maintenance costs.
The two air filter frame designs are manufactured to fit in tight spaces less than 6.35 mm or 0.25 inches thick and can be removed for service while continuing to reduce the risk of disturbing dust loaded on the filter. The frames also open for easy access to the media for simple cleaning and substitution, and the media is designed to meet NEBS standards, which require a UL Classified framed filter assembly within telecom and/or datacom chassis.
Universal Air Filter‚’s reusable frames with replaceable media meet the following standards and classifications: UL 94 HF-1; ATCA; UL 900 Class 2; CE; Telcordia; NEBS GR-78-CORE and GR-63-CORE; micro TCA; ETSI; and are RoHS Compliant.
www.uaf.com
Filed Under: Filters (mechanical) for air + fans
Mechanically cleaned filter handles chemical residue issue
EXAIR now sells 1/8 NPT siphon fed spray nozzles for non-pressurized liquids
Soft Grip air scraper from EXAIR with extension pipe
EXAIR Hot Tap Digital Flowmeters simplify installation
