    • On the Floor
REVO™ Reducing CMM Scanning Time
By Design World Staff | November 28, 2007
Renishaw’s revolutionary, ultra-high-speed scanning system for coordinate measuring machines is achieving tremendous productivity gains with early adopters.  World-class manufacturers have retrofitted existing CMMs with the new Renscan5™ system and  infinite positioning REVO™ head.  They’ve applied the system to speeding inspection on some of their more complex and time-consuming parts.
Following are results claimed by Renishaw that they’ve realized, compared to previous practice:
    •  Jet engine blisk — 922% throughput improvement.  The Inspection sequence comprised 9 section scans of the airfoil profile, 8 longitudinal scans of the blade, 2 scans of the root profile and 1 scan of the annulus profile.
    Conventional 3- axis scanning 10 mm/s         46 minutes (1 blade).
                                                 22 hrs. 14 min (all 29 blades)
    REVOTM scanning 500 mm/s                4 min. 30 sec. (1 blade)
                                                2 hrs. 10 min. 30 sec. (29 blades)
    •  Automotive cylinder head — 680% throughput improvement.  The inspection sequence comprised 12 valve seats and 3 circular scans in each of 12 valve guide bores.
    3-axis axis scanning 15 mm/s                29 min. 13 sec.
    REVOTM scanning 400 mm/s for                3 min. 42 sec.
    valve seats
    50 mm/s for valve guide bores
    •  Automatic transmission valve body – 155% throughput improvement.  The inspection sequence comprised twelve 6mm-diameter holes, six 5mm-diameter holes, 25 points on the gasket face, 45 spool bores, 3 shot scan on the gasket face and 6 points on the spool face profiles.
    Three axis scanning 15 mm/s                18 min. 5 sec.
    REVOTM scanning 500 mm/s                7 min. 5 sec.
    “These developments are revolutionizing measurement throughput,” states Denis Zayia, Renishaw’s CMM product manager.  “Besides major reductions in cycle times, Renscan5 and REVO make it possible to obtain far greater data point coverage.  REVO’s low-mass, low-inertia design allows ultra-high-speed data capture — up to 4000 points a second compared to 200-300 data points for conventional scanning.”
The agility and point-taking productivity of the Renscan5/REVO dynamic measurement system is stimulating the creativity of metrology professionals, says Zayia.  Helical scanning, for example, can greatly speed the measurement of bores, while generating thousands of data points to determine roundness, concentricity or taper.  In comparative testing, he notes, Renscan5 reduced form measurement scanning of a cylinder bore from 90 seconds to just 2.5, enabling all cylinders of a V-8 engine block to be scanned in less time than a single cylinder by conventional  methods.
A leading automobile manufacturer, he notes, is applying the system’s massive data capture capabilities to measure engines for wear analysis and deviations of the cylindricity of each cylinder in its spatial orientation.  Wear is portrayed in visual graphics similar to a thermal scan.
“Faster inspection is especially vital on large, complex, high-value parts with many critical features,” notes Zayia.  “CMM inspection can be a major bottleneck to efforts to speed throughput and gain Lean efficiencies.  Form measurement of complex parts and critical geometries for functional fits can demand many thousands of data points.  Needing to produce and document parts to ever-higher precision, ever-tighter tolerances, manufacturers are looking to CMM speed for a solution.”
As a practical matter, conventional three-axis CMMs scan at rates of 5 to 15 mm/sec in order to hold accuracy, notes Zayia.  This is to avoid high acc/dec rates and rapid axis changes that can induce inertia errors, causing deterioration in measurement accuracy.  “CMM inspection has been stuck in that time warp for over two decades,” he says.
Created under Renishaw’s longest and largest development program, Renscan5 blows away the speed limits, he says.  The Renscan5 enabling technology encompasses a range of breakthrough 5-axis scanning products that measure at up to 500 mm and 4000 data points per second, while virtually eliminating the measurement errors normally associated with existing three-axis scanning systems.
A 3-D measuring device in its own right, the REVO head features two rotary axes – one in vertical plane, one in horizontal — to give infinite rotation and positioning capability, notes Zayia. The REVO measuring head performs synchronized Y and Z axis motion to quickly follow changes in part geometry during inspection routines, he stresses, avoiding the dynamic errors caused when moving the larger mass of a CMM structure.  Where X axis motion is required for the probing routine, he says, Renscan5 moves the CMM at a constant velocity along a constant vector as measurements are being taken, removing the acceleration/deceleration inertia errors incurred in conventional scanning.
www.renishaw.com/en/7918.aspx
.: Design World :.
Filed Under: Software • 3D CAD, Factory automation, Software • CAM, Machine tools + subtractive manufacturing, SENSORS
Comments
  1. saranya s says
    December 26, 2012 at
    THE COORDINATE MEASURING MACHINE (CMM) fulfills
    current demands on manufacturing facilities to provide extremely accurate as
    well as flexible three-dimensional inspection of both in-process and finished
    parts on the assembly line. Manufacturers are under tremendous financial
    pressure to increase production and to minimize waste. Part tolerances once
    quoted in fractional figures are now quoted in thousandths of a millimeter, and
    manufacturers are under ever-increasing pressure to meet ever more demanding
    specifications on a regular basis. The CMM, which first appeared some 25 years
    ago, has developed rapidly in recent years as the state-of-the-art measuring
    tool available to manufacturers. The capabilities, accuracy, and versatility of
    the CMM, as well as the roles it will play in manufacturing, continue to
    increase and evolve almost daily. http://www.dynascan.info/coordinate-measuring-machine.php
  • Industrial automation accelerates with increased capital spending
    • On the Floor
