Rexnord announces the Dry-PT Option for select MatTop & TableTop Chains
By Leslie Langnau | June 15, 2018
Rexnord is proud to announce the latest addition to our premium line of conveying solutions products; the Dry-PT material option is now available in North America for select MatTop and TableTop chains. Dry-PT is optimized for applications where sustainability is critical, designed to maintain a constant low level of friction between the conveying chain and the bottle, run without lubrication and perform at a high level under stress. Produced in a unique lime green color to make early detection of contamination build-up easier, Dry-PT chain is ideal for PET bottle conveying applications. Available in Europe for more than two years, Dry-PT has been successfully placed in over 60 applications worldwide.
Adding Dry-PT to your operation offers the following features and benefits:
​–Runs Without Lubrication – Allows for a sustainable operation (reduced water usage)
–Engineered Specifically for PET – Friction between container and chain is consistent over time
–Engineered Polymer-based Chain – Material designed to run at high-speed without external lubrication through corners
–Bright Color Design – Material has a bright (lime green) color to make contamination buildup visible
Rexnord
www.rexnord.com
Filed Under: Factory automation, Belts + chains, Food + beverage, Material handling • converting
Tagged With: Rexnord
