Built for High Torques in Confined Spaces
The CENTAFLEX-T series was designed based on a bridge bearing principle, with high power density and good misalignment properties. Superior to other wedge-type solutions, the CENTAFLEX-T offers high performance in a compact design, omitting the hubstar thanks to optimized geometry. Available as a constant velocity driveshaft, the CENTAFLEX-T is easy to handle, with low maintenance and cost due to the reduced number of wedged elements. Installation is easy, ensuring safe integration into the drivetrain.
Optimized geometry ensures the precision design of the CENTAFLEX-T series torsionally stiff couplings are built to perform. Made for high torques in confined spaces, the CENTAFLEX-T offers high power density and good misalignment properties. The CENTAFLEX-T is low-maintenance and easy to install. Standard tools ensure simple mounting to save you time and money.
Rexnord
www.rexnord.com
Filed Under: Coupling Tips
