    • On the Floor
Rexnord filament bearings
By Mike Santora | September 10, 2021
Duralon-Photo-s-Sept-2006-002_1Rexnord filament bearings are truly on the cutting edge of bearing solution technology. Filament wound bearings are versatile and ready for use in a wide variety of applications. The self-lubricating nature of the liner combined with the high-strength and corrosion-resistant support matrix allows these bearings to operate with little to no maintenance, even under extreme conditions. The woven Teflon fiber-liner requires no lubrication, and the filament wound fiberglass and epoxy resin matrix produce a bearing that’s design flexible, maintenance-free, strong, and lightweight: the perfect bearing solution. Rexnord filament bearings commonly replace bronze bushings, brass bushings, copper bushings, Babbitt metal bushings, plastic bushings, steel ball bearings, plastic ball bearings, and other lubricated bearing materials.
Rexnord
www.rexnord.com
Filed Under: Bearing Tips
Tagged With: Rexnord
    • On the Floor
