Rexnord HTX7748 MatTop Chain Launches Worldwide
By Marisa Martin | July 18, 2016
Designed for shrink-wrap case packers in high temperature heat tunnels, Rexnord recently launched its new Rexnord HTX7748 MatTop Chain. Customers around the globe with operations in the beverage & liquid and food industries will benefit from reduced oxidation, increased uptime, reliability, and more. unnamed
As the latest addition to the comprehensive line of high-strength conveying chain, the Rexnord HTX7748 MatTop Chain provides customers with:
  • 42 percent open area and a smooth surface — supports heat dissipation through cooling cycles.
  • Proprietary and specially engineered heat stable material — withstands heat to cooling cycles of heat tunnels, ensuring uniform cooling while also allowing for easy release of materials — resulting in less scrap, more uptime, and longer chain life.
  • Engineered design for high performance and reliability — offers a heavy-duty plug and retention feature, stainless steel pins, and the Rexnord 7700 Series MatTop Chain proven base design; pins remain in place, providing a stronger chain and easy link replacement when needed.
  • Technical expertise — the combination of our chain design and technical expertise helps customers choose durable conveyor systems that guarantee optimal product handling.
Rexnord
www.rexnord.com
Linear Motion Tips
Tagged With: Rexnord
Beckhoff optimizes linear motion with machine learning solution that eliminates cogging
PI offers new stepper motor translation stages for precision automation
Linear axis provides precision, stability for semiconductor manufacturing equipment
Lead-screw assemblies from igus for automotive applications
