Rexnord launches 390 Series Chain for beverage industry
By Leslie Langnau | February 19, 2018
Designed to optimize tight transfers in the beverage, food, metal container manufacturing, and pharmaceutical industries, Rexnord launches the Rexnord 390 Series MatTop Chain.
The 395 MatTop plastic modular chain features a flat top execution while:
–Reducing product damage & loss — with an 8 mm pitch, the chain can go around a nose bar diameter of 6 mm for tight transfers of small footprint & unstable products
–Minimizing risk of chain failure — can carry more load and withstand high peak loads with high strength feature
–Decreasing downtime — high stiffness allows less risk of material fatigue and pin wear, providing optimal chain tracking; chain does not jump on the sprocket with optimized sprocket engagement
–Mitigating product contamination — headless rod with self-locking pin retention; fewer and less complicated tools, assembly and maintenance
Key applications include tight transfer (“knife edge”) conveyors; small product handling where stability of container or delicate nature of product is critical to operation; transitions or transfers between two mass flow conveyor sections; and package and case transfers into and out of packers, turns and spiral conveyors.
Rexnord
www.rexnord.com/390series
Filed Under: Factory automation, Conveyors, Food + beverage, Material handling • converting
Tagged With: Rexnord
